The whiteboard doesn't work in Microsoft Edge and I tried all the solutions that I found but still didn't work. I just installed Chome and it worked well in Chrome.
What is the exact issue with Edge?
Here is the log when I load the whiteboard, that might help
have the same issue with Edge and everything is working with Chrome
You may refer to this article: https://support.atlassian.com/confluence-cloud/docs/browser-support-and-settings-for-whiteboards/
might help!
I already checked that page, everything is correct and hardware acceleration is enabled too.
There are some Troubleshooting steps also mentioned there in the article:
If that also does not help, contact Atlassian support here.
