from no reason, probably after some update.. I have this error shown and I am not so clever from the log file also!.
Can you please have a look?
The database is running fine, password, login, port is OK.
i have no idea what else :(
Hosted on 2016 server
log file:
2019-02-15 10:12:49,376 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#1] [mchange.v2.resourcepool.BasicResourcePool] log Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@5a4d714c is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
2019-02-15 10:12:49,376 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#0] [mchange.v2.resourcepool.BasicResourcePool] log com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@1b89b3e1 -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user 'Confluence'. ClientConnectionId:abe1bd6b-664e-467c-a19c-3cce34ce72e3
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:260)
at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(tdsparser.java:256)
at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:108)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:4507)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:3374)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$100(SQLServerConnection.java:85)
at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:3338)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7342)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2688)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:2236)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:1897)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1738)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1062)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:572)
at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:175)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:220)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:206)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:203)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1138)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquireAndDecrementPendingAcquiresWithinLockOnSuccess(BasicResourcePool.java:1125)
at com.mchange.v2.resourcepool.BasicResourcePool.access$700(BasicResourcePool.java:44)
at com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask.run(BasicResourcePool.java:1870)
at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:696)
2019-02-15 10:12:49,376 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#0] [mchange.v2.resourcepool.BasicResourcePool] log Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@5a4d714c is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
2019-02-15 10:12:49,376 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#2] [mchange.v2.resourcepool.BasicResourcePool] log com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@44f3a8fb -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user 'Confluence'. ClientConnectionId:f3df2578-397f-435d-aac4-70820591187d
2019-02-15 10:12:49,376 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#2] [mchange.v2.resourcepool.BasicResourcePool] log Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@5a4d714c is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
2019-02-15 10:12:49,391 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#1] [mchange.v2.resourcepool.BasicResourcePool] log com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@48661f62 -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user 'Confluence'. ClientConnectionId:6404b3bc-6105-4a32-8f55-5ec81b338030
2019-02-15 10:12:49,391 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#1] [mchange.v2.resourcepool.BasicResourcePool] log Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@5a4d714c is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
2019-02-15 10:12:49,407 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#0] [mchange.v2.resourcepool.BasicResourcePool] log com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@29cbee2c -- Acquisition Attempt Failed!!! Clearing pending acquires. While trying to acquire a needed new resource, we failed to succeed more than the maximum number of allowed acquisition attempts (30). Last acquisition attempt exception:
com.microsoft.sqlserver.jdbc.SQLServerException: Login failed for user 'Confluence'. ClientConnectionId:869c41e5-cbed-4f97-a0b8-a9012abbf827
2019-02-15 10:12:49,407 WARN [C3P0PooledConnectionPoolManager[identityToken->1hge135a01uosxe315jhus3|ce649ea]-HelperThread-#0] [mchange.v2.resourcepool.BasicResourcePool] log Having failed to acquire a resource, com.mchange.v2.resourcepool.BasicResourcePool@5a4d714c is interrupting all Threads waiting on a resource to check out. Will try again in response to new client requests.
@Lukas Brezina If you claim that user password that you use to connect confluence is correct , Now ensure that database server is in the same network with confluence.
see more info here Connecting JIRA to Database
Hi @Lukas Brezina- what Confluence version are you running, what DB do you use (MSSQL, MySQL, etc) and version. Also ask you DB Administrator to check the permissions for that user on the DB and maybe change the password for that account and modify it in the Confluence config file.
Hello Mihai,
6.14.
Microsoft SQL 17
We changed the password just for sure and modife the file, but still we have the ...picture...
@Lukas Brezina- did you tried to login into the DB using the same credentials that you used for Confluence? Also try to ping the DB from your Confluence server (just to exclude this).
