×Red square is personal space link. Can i move it to green square links and make red square link same style as green and be right above green square links?
And also the same for "Glossary" link too .Which is under red square.
Without ikon of house in red square. And be in one common style ?
I also add photo of how i like to see my links in final form. Is it possible without JS ?
Hi!
Do you mean customization without JS?
So JS is vise versa cheapest way to customization :)
i mean i woul like to understand if there is a solution out of the box
So you create a fake page which will appear on that tree.
Then you can put redirect macro or info to redirected to another page.
I uderstand your idea. Its nice but how it will direct me to my destination( because after i will click on that fake page it will bring me to that fake page not to my desire one in the red square) ?
Like how i can add link to that fake page. Maybe you can describe your first solution with "redirect macro" because i dont quite get it.
Because info on the page where to redirect is not suited for me.
Its a solution. And if i want simply Pull down existing link , only JS can help me ?
The only bad thing about your sollution is that dots (
