Copy from Code Macro
Ami Chidori
March 3, 2021
Hi!
We have a lot of articles with code blocks and often need to copy text from one.
But it will be more comfortable and userfiendly to make it with button, like "Copy code from this block"
Does any way to create button with some action exist?
Danyal Iqbal
March 3, 2021
double click on the code to copy all code in the macro and than copy paste like you normally do.
You could write a a script to add the button and add it to the html macro, if you really need to.
Ami Chidori
March 4, 2021
thanks! double click works.
I tried to create html-block with copy button but it has not work yet. I don't understand  and can't find answer in google how to copy text from one no-html-block like code macro
Like Jürgn likes this
