Draw.io infinite load when attempting to edit diagram
Tristan Wilson
April 23, 2019
When attempting to open and edit an existing diagram we're taken back to Confluence and presented with a blank screen with a loading wheel that spins forever.
Bill Tanner February 6, 2020
We are having the same problem.  Any updates on this?
David Benson _draw_io_
February 6, 2020
This thread is Confluence Cloud, you're using Server, it's not the same issue.
Jeff Scattini
Getting the exact same response.
Open Confluence Edit view on a page where draw.io macro has been placed. Click macro, click Edit to edit macro.
Receive a "Loading app" message with endlessly spinning wheel. Been about 4 hours now and draw.io still has not loaded.
August 21, 2019
Ad blocker blocking the draw.io domain from loading?
Jeff Scattini
Nope. Could it be related to VPN?
Marija Radovic
Hi Tristan,
Could you tell me, please:
* do you experience the same problem in another browser and Incognito mode?
* can you create a new diagram and edit it?
* what steps did you perform? did you try to edit it via: Page edit pencil icon. Page view pencil icon and "draw.io diagrams" section (can be seen on the left when space is chosen)
As a workaround, you can try to download a file and add it back to Confluence page as a new attachment.
If nothing helps, it would be great if you could send us "Attachments" and "View format panel" (when on Confluence page with a diagram, click three dots on the top right)
You can always contact us at support@draw.io if you wouldn't like data to be shown here publicly.
Thanks, Marija
April 24, 2019
Can you submit details to support@draw.io please?
