Hi, I am looking for a method to filter pages containing a specific label and include their child pages regardless of their labels in the Confluence cloud.
I am starting an archiving and approval process, and based on the parent page, the children's pages' "fate" will be decided.
Tami
Hi @Tami Dubi
Can you please clarify what you mean here?
Are we speaking of Jira or Confluence? Issues are a term for Jira and pages are for Confluence. I’m not sure if your usage here are as per terms you use internally but as a standard Issues is a reserved term for Jira.
Also when you say filtering, confluence has a search and I’m unaware of it having filters which makes the whole description very confusing.
Clarify this and we will see how we can help.
Thanks for the clarification. To my knowledge confluence doesn’t have a functionality of showing you child pages of a page via a search even under advanced search. The option open to you is to add the same label to the child pages.
Regards.
