How to print checkboxes for HTML output
Casey Maynard
I have pages with checkboxes.  But when I export the page to HTML format, the checkboxes appear as bulletpoints.  How can I get the checkboxes print, both in a checked or uncheck state?
SMS
November 2, 2017
Hi Casey,
It appears this is a known issue in Confluence Server:
Could you let me know what version of Confluence you're on, so I can update the bug with your information?
A workaround would be to manually edit the HTML and include the desired checkbox: <input type = "checkbox">
Let me know if you have any questions.
Kind Regards,
Shannon
Casey Maynard
We are using 6.5.0.
This issue has been opened since 2014, so I doubt there will be any fix for this issue.
And the workaround is not easy to do or practical, as most of my documents have checkboxes.
I regret that I am forced to use this application, because it lacks quite a number of commonly needed functions, or it requires a user to buy a number of plugins.
Casey Maynard
Is there another workaround?  I have 35 different pages that have some sort of 'checkbox' option that I would need to edit
SMS
November 21, 2017
Hi Casey,
At this time there is no further workaround. I recommend watching this thread and the bug in case another workaround is discovered.
Shannon
Casey Maynard
Amazing.  Checkboxes are a common everyday item on documents.  And this has been a design flaw open for over 3 years, no solution, and it is not even under consideration.
I cannot imagine that Confluence users have not found a solution, not even a simple 'checkbox' add-on.  I guess this community is not big enough for someone to provide simple solutions.
Like Thomas Friedrich likes this
