Is anyone else seeing intermittent issues with the Confluence Server editor after upgrading to 7.14.1? We've had:
All off and on - don't seem to be tied to a particular user or browser.
Have tried a reboot, next move is to temporarily turn off collaborative editing and see if that helps.
Do you use any apps? There seems to be a bug in version 7.14.1.
Hi Andrey. We have quite a number of apps in use - including your Table Filter and Charts. All are up to date. Can you share any further info on the bug you've seen?
Hi Phil,
Please, try to disable the inline macro insertion feature.
Thanks for the tip. We'd turned off collaborative editing and had had no problem reports. I disabled the feature as suggested late last week, and now have turned back on collaborative editing, so we'll see how it goes today.
No problems (other than expected ones from the editing changeover) seen.
Atlassian opened a bug in Confluence: https://jira.atlassian.com/browse/CONFSERVER-74869. Please, vote for it.
Also, we've released version 7.9.24 with a workaround that might fix the issue.
