I have a page where I am setting up the four following forms:
-Project (top level)
-Task type 1
-Task type 2
-Task type 3
Each of the task types have a smart dropdown to select an associated project record. Then I'm trying to filter a task display based on project info later on, but I'm running into issues. To troubleshoot I tried displaying some task field values in a table and saw the following:
-The "Task Name" field is correct and is a simple text field.
-The "Project" is the smart dropdown. Simply "project" for the fieldName.
-The "Entity" shows up as blank. This is "project.entity" for the fieldName and should reference the entity field in the project form, which is a radio group.
-The "Project Name" shows up three times for some reason. This is "project.name" for the fieldName and should reference the name field in the project form, which is a text field.
-The "Installation Date" seems to default to 12/31/1969. This is "project.date" for the fieldName and should reference a date field in the project form. This date field is not 12/31/1969.
I'm clearly doing something wrong here, anyone have any info that could help me get back on track? Thanks.
What is the configuration of the form that this "project" smart dropdown is linked to?
What field sit has and what is their configuration?
I might guess about the date - must be a custom formatting used that is not quite right - how is the "date" field configured?
Alex
Hi Alex-
Thanks for the response. I think I've figured out some of the weirdness for now...I had a tableview merger earlier in the page and I didn't realize that affected things outside of the macro. I removed that and I'm back on track now.
Thanks again!
Awesome, glad you have figured it out!
