×My JIRA Issue/Filter does auto expand to show me the results.
I have a similar query that does show auto expanded, but I have one that does not show the results, unless I click the grey arrows in the column title that is displayed.
I had hoped this filter would allow a better display of the results. I do not want the column header to display, nor do I want the 'Showing 1 of 3' section.
I really only want the results to be displayed, not anything else.
Is there a way to fix the autoexpand issue?
Is there a way to customize the display layout of the issue filter?
Hi Casey,
You may customize the way the filter is displayed by editing the macro and choosing Display Options:
Ann
Maybe my title is not clear on what my issues are
1. I have a JIRA filter that does not display the results by default. I have to click the expand button to have the results show. Note: I have a similar query that does 'auto-expand' to show the results, so I do not know why the first one does not auto-expand.
2. The other issue is that the results for the JIRA filter has 'extra' content
I do I want the 'Showing 1 of 3' section.
Hi Casey,
Please edit the macro that expands and the one that does not and compare the settings to find which setting is different.
I was unable to eliminate all the column header rows. If you have feedback for the development team regarding the way the macro should display for your use case, please create a suggestion on our bug tracker: https://jira.atlassian.com
Ann
