Need help in Table Calculations using SQL query in Confluence Table Transformer Macro
Jitendra Shembekar
Hi
Trying to get multiplication result in the last column of the below table. I am using table transformer sql query. Query itself does not give any error but it gives below error after publishing it.
Please help.
Table used
RangeActual ValueC1C2Multiplication
20211100
30290.550
40880.550
  • Want to put multiplication of C1 and C2 values under Multiplication column
  • SQL used in Table Transformer is
    • UPDATE T1 SET T1.'Multiplication' = T1.'C1'*T1.'C2'
  • Error I am getting
    • TypeError: Cannot read properties of undefined (reading 'C1')
How to resolve this?
3 votes
Stiltsoft support
Hi @Jitendra Shembekar ,
Please use the following query for the case:
UPDATE T1
SET T1.'Multiplication' = ('C1' * 'C2');
SELECT * FROM T1
Jitendra Shembekar
Excellent ... that worked!
Thanks a lot @Stiltsoft support
Like # people like this
