Hi ,
My Jira URL is like http://<port_number>:8080/
I want to change the http to https and also want to update the port number as well.
I might need SSL related documentation too for this to acheive.
Can you please help to share me any guide with step by step procedure.
Thank you,
Manoj.
Here is a guide to get you started - https://confluence.atlassian.com/doc/running-confluence-over-ssl-or-https-161203.html just make sure to change the version to the version of Confluence you are running
Thank you for the response, Kristin.
I will use this for Confluence, however I require the same for Jira too.
