I get folowing errors after upgrading confluence.
Upgrade failed. Please consult the system logs for details. You will need to fix these problems, restore your database and confluence home directory to the pre upgrade state. Then retry the upgrade. Upgrade error message: Upgrade task com.atlassian.confluence.upgrade.upgradetask.DropSpaceGroupTablesUpgradeTask@4a0342c5 failed during the SCHEMA_UPGRADE phase due to: null
i have following logs in "/opt/atlassian/confluence/logs"
atlassian-synchrony-proxy.log
catalina.out host-manager.2019-04-12.log
catalina.2019-04-12.log
gc-2019-04-12_19-29-11.log.0.current localhost.2019-04-12.log
synchrony-proxy-watchdog.log
and in "/var/atlassian/application-data/confluence/logs"
https://de.files.fm/u/wqgvtr5r <-- download
atlassian-confluence.log
atlassian-diagnostics.log
atlassian-synchrony.log
where i can find more details?
i reinstall the db several time... im lost :(
Hi Thomas
can you check if you might hit
and see if the workaround solves your issue
Cheers
Kurt
i try this one but it doesn't work:
#1072 - Key column 'SPACEGROUPID' doesn't exist in table
I add the new Logs - http://kathriner.com/atlassian-confluence.log
Still not running. :(
There is one error
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Unknown column 'spacepermi0_.PERMALLUSERSSUBJECT' in 'field list'
pointing to permissions tables, could you check
From which to which version are you upgrading
Cheers
Kurt
I try this one too. Stil same Error... i Upload the new log - http://kathriner.com/atlassian-confluence-new.log.
i think it was Version 5.4 i have the file-backup not here.
Hi Thomas
so you have a valid license in place as well as the collation of the database is correct - right?
Cheers
Kurt
And just to double check, from which version to which version are you upgrading
i try to go back on the old version:
Detected tables with non-default collation. See https://confluence.atlassian.com/x/TABrFw
i get some errors if i try to change the collation:
ALTER TABLE `AO_950DC3_TC_CUSTOM_EV_TYPES` CHANGE `BELONG_SUB_CALENDAR_ID` `BELONG_SUB_CALENDAR_ID` VARCHAR( 255 ) CHARACTER SET utf8 COLLATE utf8_bin NULL DEFAULT NULL
#1025 - Error on rename of './bak_atlassian@002dconfluence/#sql-37a_d062' to './bak_atlassian@002dconfluence/AO_950DC3_TC_CUSTOM_EV_TYPES' (errno: 150)
Any chance that your tables are using MyISAM instead of InnoDB?
