×Good day!
After restarting server contained confluence, its web interface became unavailable, chrome say:
ERR_CONNECTION_REFUSED
Java process started
[root@confluence conf]# ps -aux | grep java
conflue+ 4677 111 45.0 4284816 1097088 ? Sl 17:20 15:28 /usr/local/confluence/jre//bin/java -Djava.util.logging.config.file=/usr/local/confluence/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djdk.tls.ephemeralDHKeySize=2048 -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -XX:ReservedCodeCacheSize=256m -XX:+UseCodeCacheFlushing -Dconfluence.context.path= -Datlassian.plugins.startup.options= -Dorg.apache.tomcat.websocket.DEFAULT_BUFFER_SIZE=32768 -Dsynchrony.enable.xhr.fallback=true -Xms1024m -Xmx1024m -XX:+UseG1GC -Datlassian.plugins.enable.wait=300 -Djava.awt.headless=true -XX:G1ReservePercent=20 -Xloggc:/usr/local/confluence/logs/gc-2019-06-25_17-20-05.log -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=5 -XX:GCLogFileSize=2M -XX:-PrintGCDetails -XX:+PrintGCDateStamps -XX:-PrintTenuringDistribution -Dignore.endorsed.dirs= -classpath /usr/local/confluence/bin/bootstrap.jar:/usr/local/confluence/bin/tomcat-juli.jar -Dcatalina.base=/usr/local/confluence -Dcatalina.home=/usr/local/confluence -Djava.io.tmpdir=/usr/local/confluence/temp org.apache.catalina.startup.Bootstrap start
Port 8090 open:
[root@confluence conf]# netstat -na | grep 8090
tcp6 11 0 :::8090 :::* LISTEN
firewall clean:
[root@confluence conf]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
contents of the log file catalina.out:
25-Jun-2019 17:20:05.763 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server} Setting property 'debug' to '0' did not find a matching property.
25-Jun-2019 17:20:05.854 WARNING [main] org.apache.catalina.startup.SetAllPropertiesRule.begin [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'debug' to '0' did not find a matching property.
25-Jun-2019 17:20:05.973 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server/Service/Engine} Setting property 'debug' to '0' did not find a matching property.
25-Jun-2019 17:20:05.980 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server/Service/Engine/Host} Setting property 'debug' to '0' did not find a matching property.
25-Jun-2019 17:20:06.028 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'debug' to '0' did not find a matching property.
25-Jun-2019 17:20:06.056 WARNING [main] org.apache.tomcat.util.digester.SetPropertiesRule.begin [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'debug' to '0' did not find a matching property.
25-Jun-2019 17:20:06.378 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8090"]
25-Jun-2019 17:20:06.395 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
25-Jun-2019 17:20:06.408 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 773 ms
25-Jun-2019 17:20:06.427 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Tomcat-Standalone]
25-Jun-2019 17:20:06.427 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/9.0.12
25-Jun-2019 17:20:08.816 INFO [localhost-startStop-2] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were s
25-Jun-2019 17:20:09.348 INFO [localhost-startStop-2] org.apache.catalina.core.ApplicationContext.log Spring WebApplicationInitializers detected on classpath: [com.atlassian.synchrony.proxy.SynchronyDispatcherServletInitializer@163a97fd]
25-Jun-2019 17:20:09.907 INFO [localhost-startStop-2] org.apache.catalina.core.ApplicationContext.log Initializing Spring FrameworkServlet 'dispatcher'
25-Jun-2019 17:20:09.907 INFO [localhost-startStop-2] org.springframework.web.servlet.DispatcherServlet.initServletBean FrameworkServlet 'dispatcher': initialization started
25-Jun-2019 17:20:09.923 INFO [localhost-startStop-2] org.springframework.web.context.support.AnnotationConfigWebApplicationContext.prepareRefresh Refreshing WebApplicationContext for namespace 'dispatcher-servlet': startup date [Tue Jun
25-Jun-2019 17:20:10.036 INFO [localhost-startStop-2] org.springframework.web.context.support.AnnotationConfigWebApplicationContext.loadBeanDefinitions Registering annotated classes: [class com.atlassian.synchrony.proxy.websocket.WebSock
2019-06-25 17:20:10,226 INFO [localhost-startStop-1] [com.atlassian.confluence.lifecycle] contextInitialized Starting Confluence 6.15.1 [build 8100 based on commit hash 655541fd8de32cde09f1d3f09341851d946007a5] - synchrony version 2.1.0-
25-Jun-2019 17:20:10.812 INFO [localhost-startStop-2] org.springframework.scheduling.concurrent.ThreadPoolTaskScheduler.initialize Initializing ExecutorService 'defaultSockJsTaskScheduler'
25-Jun-2019 17:20:10.907 INFO [localhost-startStop-2] org.springframework.web.socket.server.support.WebSocketHandlerMapping.registerHandler Mapped URL path [/v1/bayeux-sync1] onto handler of type [class org.springframework.web.socket.ser
25-Jun-2019 17:20:11.617 INFO [localhost-startStop-2] org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerMapping.register Mapped "{[/healthcheck]}" onto public com.atlassian.synchrony.proxy.web.HealthCheckResult c
25-Jun-2019 17:20:11.619 INFO [localhost-startStop-2] org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerMapping.register Mapped "{[/reload],methods=[PUT]}" onto public org.springframework.http.ResponseEntity com.
25-Jun-2019 17:20:11.664 INFO [localhost-startStop-2] org.springframework.web.servlet.handler.SimpleUrlHandlerMapping.registerHandler Mapped URL path [/**] onto handler of type [class org.springframework.web.servlet.resource.DefaultServl
25-Jun-2019 17:20:11.759 INFO [localhost-startStop-2] org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.initControllerAdviceCache Looking for @ControllerAdvice: WebApplicationContext for namespace 'dispat
25-Jun-2019 17:20:12.043 INFO [localhost-startStop-2] org.springframework.context.support.DefaultLifecycleProcessor.start Starting beans in phase 2147483647
25-Jun-2019 17:20:12.097 INFO [localhost-startStop-2] org.springframework.web.servlet.DispatcherServlet.initServletBean FrameworkServlet 'dispatcher': initialization completed in 2189 ms
ping sever from client is ok.
need help.
thx.
after that, the confluence began to display a database connection error
but that's not clear, we used the initial version of the database (without sql)
and i did not delete anything before the problem, what kind of connection to the database are we talking about?
that's what I noticed:
three hours after the launch of confluence, this is what appeared in the log file (see attach)
Check the write rights to the logfiles or the directory permissions. I recently had a similar problem and the wrong rights to the logfiles. The message looked at least similar.
regards
Juergen
im rewrite all privilegies to confluence1:confluence1, and restart confluence
[root@confluence confluence]# ls -la
итого 336
drwxr-xr-x 14 confluence1 confluence1 4096 мар 21 16:14 .
drwxr-xr-x. 15 root root 4096 мар 21 16:13 ..
drwxr-xr-x 3 confluence1 confluence1 4096 мар 21 16:13 bin
-rw-r--r-- 1 confluence1 confluence1 19764 мар 14 06:10 BUILDING.txt
drwxr-xr-x 3 confluence1 confluence1 4096 мар 21 16:13 conf
drwxr-xr-x 27 confluence1 confluence1 4096 мар 21 16:13 confluence
-rw-r--r-- 1 confluence1 confluence1 6242 мар 14 06:10 CONTRIBUTING.md
drwxr-xr-x 3 confluence1 confluence1 4096 мар 21 16:14 .install4j
-rw-r--r-- 1 confluence1 confluence1 83586 мар 21 16:14 install.reg
drwxr-xr-x 5 confluence1 confluence1 114 мар 21 16:13 jre
drwxr-xr-x 2 confluence1 confluence1 4096 мар 21 16:13 lib
-rw-r--r-- 1 confluence1 confluence1 58153 мар 14 06:10 LICENSE
drwxr-xr-x 2 confluence1 confluence1 45056 мар 21 16:13 licenses
drwx------ 2 confluence1 confluence1 4096 июн 26 16:51 logs
-rw-r--r-- 1 confluence1 confluence1 1862 мар 14 06:10 NOTICE
-rw-r--r-- 1 confluence1 confluence1 2294 мар 14 06:10 README.html
-rw-r--r-- 1 confluence1 confluence1 3334 мар 14 06:10 README.md
-rw-r--r-- 1 confluence1 confluence1 1204 мар 14 06:10 README.txt
-rw-r--r-- 1 confluence1 confluence1 7030 мар 14 06:10 RELEASE-NOTES
-rw-r--r-- 1 confluence1 confluence1 16738 мар 14 06:10 RUNNING.txt
drwxr-xr-x 4 confluence1 confluence1 35 мар 21 16:13 synchrony-proxy
drwx------ 7 confluence1 confluence1 4096 июн 25 14:20 temp
-rwx------ 1 confluence1 confluence1 13569 мар 14 06:10 uninstall
drwxr-xr-x 2 confluence1 confluence1 6 мар 14 06:10 webapps
drwx------ 3 confluence1 confluence1 42 июн 26 16:51 work
but that didn't change anything
