Edit: 2022.10.25
Today I created a virtual server and installed a new clean (no data) confluence version 5.5.7 and then run the upgrade to version 5.6.6. I am getting the same error. There must be something wrong.When I test going to the 5.10.9, I'm getting missing column error:
Error occurred during template rendering: Invocation of method 'isUsesCustomLogo' in class com.atlassian.confluence.plugins.lookandfeel.SiteLogoVelocityHelper threw exception org.springframework.jdbc.BadSqlGrammarException: Hibernate operation: Could not execute query; bad SQL grammar []; nested exception is java.sql.SQLException: Invalid column name 'HIBERNATEVERSION'. at /decorators/includes/common-header.vm[line 23, column 22]. Contact your administrator for assistance.
Hello. It seems that there was one more intermediate step between the older standalone version of the license and the newer datacenter version of the license. For this reason, neither the old nor the new license worked. A new middle license prepared by the atlassian solved the bug.
I would suggest that you contact directly Atlassian's support (support.atlassian.com/contact)
Nice! Let us know here the outcome
hi @Jiří Josefus , may I know if you can get the issue resolved?
