Problem with unicode in document preview
Райля Нигматуллина November 14, 2017
Problem with unicode in document preview.
Text language Russian:
Gonchik Tsymzhitov
Could you provide your Confluence version?
And it will be good, if you provide more deatails like, which document gets problem. It is pdf, doc, docx, etc.
Kindly could you use this instruction for troubleshooting.
https://confluence.atlassian.com/doc/troubleshooting-character-encodings-167194.html
Gonchik Tsymzhitov
Confluence version 5.7.3 and it is doc. The link did not help.
Railya Nigmatullina
Gonchik Tsymzhitov
Well,
I have tested on 6.3.4, 6.5.0 - everything is ok.
Could you provide info about fonts and what about text in russian on the page?
Could you check it with this example:
http://ofk41.narod.ru/docs/password_oos.doc
Anyway, have you create a  ticket here https://getsupport.atlassian.com ?
I hope it helps you
Gonchik Tsymzhitov
Райля Нигматуллина November 15, 2017
This problem happened after the migration from Windows to Linux.
The request was not created here  https://getsupport.atlassian.com
