I have established several pages with information that is extracted in various page properties reports. In two of the fields there are dates. When I am on the source page the calendar works fine when I click on the date and try to change the date. However, when I click on the date in table in a page properties report a date several years later is suggested. I have tried to restart, try different browsers and looked to any settings to change, but can't figure it out. Any suggestions?
Hello @mfw ,
Most likely, you're using the Handy Macros for Confluence app (this feature is not provided by default in Confluence).
Please contact our support team so we'll be able to investigate the issue and fix it.
Thank you!
Hi, thank you for your message. Best regards Morten
Update: the issue has been fixed in version 3.1.1 of the app.
