Questions for inserting tables and images
Haeryong An September 11, 2021
1. I wonder how to insert two images on the same line. It was definitely possible at the old editor, but I don't know how to deal with it in this new editor system
2. Whenever I am trying to put the table on the line, it always goes to the end of the page. I just want to insert it between the lines, but I have no idea.
Nic Brough -Adaptavist-
September 11, 2021
It's not quite side-by-side on the same line as I think of it, but you can use layouts to get two or three images next to each other.
When your cursor is on the line you want the images on, hit the "layout" button (it's two vertical rectangles side-by-side towards the right hand side of the edit bar).  This will let you insert a line with two or three columns, with some sizing options, which you can then put your images in.
On the tables thing, I am not sure I understand the description of the problem.  If I put the cursor where I want to start a table, and hit the table button, I get a table inserted at that point.  I am not sure whet "it always goes to the end of the page" means?
Haeryong An September 12, 2021
As you see below, any kind of layouts, tables goes to the end of the page. My purpose is to insert them between a and b, but I have no idea. Is it the exceptional situation of my system?
September 12, 2021
Oh, hang on, you're trying to insert a table as a list item.  That's not supported, bullet/numbered lists are expected to be plain simple text - a word, clause or a short sentence.
It's not going "to the end of the page", it's adding the table below the list.
To do a table inside a set of named items, you probably want to stop trying to do it as a list and do them as headings instead.
Like Haeryong An likes this
FREE
