I can't get TOC macro to populate the summary and status when I use the Jira macro set to Header1. Are there any hints/tips to get this working please?
I have pages with lots of Jira macros on them (set to Header 1) and this one has only 1 Jira. The TOC never retrieves the Jira details. Like this...
Versions we are on:
Confluence 8.5.6 (i-0cd4284c5c0532f6d: 24e2ed46)
Atlassian Jira (v9.12.2#9120002-sha1:301bf49:i-0e0505b952c2bf4d7)
To be sure I understand. This works as expected on your other pages that have multiple Jira gadgets set as H1s, yet on this page with only 1 gadget it does not work?
I'd create a test page and see if you can recreate this. If so, does adding a 2nd gadget fix it? If so you have probably discovered a bug and can report it to Atlassian. If creating a test page doesn't recreate the issue, then there is something amiss with that other page, and you could replace it with your test page.
Hi Shawn.
All pages do it. I have probably 150 pages all with the same problem. Yes I can recreate it over and over again very easily.
I've attached screen shot of a new page I have created this week. It has many Jira links set as Header1. The TOC picks them up but doesn't display their summaries. Like it is drawing the TOC before the Jira info has been retrieved(?).
The screen shot shows me using the standard TOC Macro as well as the TOC Zone macro to see if that is any better. The TOC Zone macro has the same problem
