Unable to render Jira issues macro. Connection to Jira has timed out.
Omar Mezrag
July 24, 2019
Hi ,
Please I need your support to solve an issue I'm facing when using Jira filter Macro.
The warning message appear when using Jira Macro filter:
View these issues in Jira
knowing that, the connection between Jira and confluence work properly , other macro work without problem like Jira chart.
In below you have  the capture screen that illustrates the Jira filter and Jira chart
Stephen Sifers
July 26, 2019
Hello Omar and welcome to the Community.
We appreciate you including screenshots along with the error message you’re seeing. This issue does seem to be related to a KB we have. The KB references that newer versions of Jira/Confluence show this issue to be resolved as the impacting bugs for this have been resolved as well. Could you please review Timeouts in the JIRA Issues Macro or Highlighting Plugin and see if this helps to resolve your issue.
If you’re having issues while on the latest version of Jira/Confluence, please reach out and let us know.
Stephen Sifers
Omar Mezrag
August 1, 2019
HI Stephen,
Many thanks , solved
Regards.
Omar Mezrag
Like Stephen Sifers likes this
rolland_vandersluis
This is happening in our company today. We're using (Data Center) Confluence 7.19.16.
2024-02-26 (Unable to render jira issues macro. Connection to Jira has timed out.).png
