Why does not it work ssl https
Fred Kruger June 3, 2020
Hi, I can not understand why https does not work.
Here is what i did:
Test server.
1) Installed a certificate issued by mine CA
keytool -import -trustcacerts -file cert.cer -alias tomcat -keystore "/opt/atlassian/confluence/jre/lib/security/cacerts" -storepass changeit -noprompt
2)Fixed configuration file
<Connector port="8443" maxHttpHeaderSize="8192"
maxThreads="150" minSpareThreads="25"
protocol="org.apache.coyote.http11.Http11Nio2Protocol"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocols="TLSv1,TLSv1.1,TLSv1.2"
sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2" SSLEnabled="true"
URIEncoding="UTF-8" keystorePass="changeit" keystoreFile="/opt/atlassian/confluence/jre/lib/security/cacerts"/>
3)Changed the base url https://myname:8443 and restarted confluence.
In the end, I get ERR_CONNECTION_REFUSED.
How to determine the cause? There is nothing in the logs.
I will be glad to any suggestions) Thanks
repi
June 3, 2020
@Fred Kruger
What is the format of the key file?
If in format # PKCS12 then the entry add keystoreType = "PKCS12".
Fred Kruger June 4, 2020
You were right in java.security file i found the line keystore.type=pkcs12 . I added to file server.xml keystoreType = "PKCS12" but it did not help. I also tried this keyAlias="tomcat" but unsuccessfully (: Thanks
You pushed me to study the documentation of tomcat and it worked for me!) I changed the configuration, but https worked!
SSLCertificateFile="/mycert.cer"
SSLCertificateKeyFile="/my-key-rsa.key"/>
