Receive an error when using the searching for a JIRA issue from Confluence
jiraguy
Hi there,
I am receiving an error when I attempt to search for JIRA issues from Confluence. The error I see is Received the following HTTP error code from the server:0. I thought it might be the application links but I am able to see/do everything else. I am able to:
- Create a new issue in JIRA from Confluence
- See my most recently views issues in Confluence
- Add Gadgets from Confluence to a JIRA Dashboard
- See the wiki link on the JIRA issue created in Confluence
That makes me think that it isn't an application link issue.
Best,
Graham
hsuhailah
March 19, 2013
This issue has been fixed in Confluence 5. I've tested it out and confirm its working. Give it a check.
François Nonnenmacher February 27, 2013
Same error here, no error show up in the logs. I found this: https://jira.atlassian.com/browse/CONF-27506 unfortunately it was closed by Atlassian because they couldn't reproduce it :-(.
