Reference containing entry from a Smart Multirow entry
Demolag
Is it possible to reference the containing entry from a Smart Multirow entry?
for example:
  • F1:
    • name (Text)
    • info (Text)
  • F2:
    • smr (Smart Multirow from F1)
      • name
      • info
is it possible to reference from an entry on F1 the containing entry from F2?
The closest I could think of is:
id.queryAndSet(F2:@self;smr.transform(id):*[entry.id]*;<Field Name>)
but it doesn't reference the entry, just query some of it fields.
2 accepted
Alex Medved _ConfiForms_
id.queryAndSet(F2:@self;smr:[entry.id];<Field Name>)
Same with queryAndRender  (if you want to render the field/fields from F2 related to F1)
Tomislav Tobijas
Hi @Demolag ,
I would suggest reaching out directly to the vendor with this question. I believe this is a request form you can use: Support Request Form
We didn't collaborate with Vertuna but, usually, Marketplace vendors are quite helpful and have decent response times to submitted questions or issues.
Tobi
