Refresh didn't work when using "Insert JIRA issue/Filter" Macro
Richard Coffre
Hi all,
I insert the macro 'Insert JIRA issue/Filter" in a Confluence page.
When I preview the page, everything is OK.
But when I save and see the "real" page, I have the error message "Refresh didn't work. Try again or click an issue to see it in JIRA".
Do you have any ideas?
Best regards,
Richard
NotTheRealStephenSifersNOPENOPENOPENOPE
April 16, 2018
What version of JIRA and Confluence are you presently on?
Looks like a similar issue was resolved on an older version:
https://jira.atlassian.com/browse/CONFSERVER-38687
Junio Fernandes
I have the same problem, but not using custom fields on order clause. Preview works, updated not.
My filter (sanitized):
issuetype = Bug AND Environment in (Production) AND project in (PRJA, PRJB, PRJC) AND (fixVersion in unreleasedVersions() OR fixVersion is EMPTY) AND status not in (Done) AND Origin in (Development) AND ("Epic Link" is EMPTY OR "Epic Link" not in (EP-1, EP-2)) ORDER BY status ASC, project ASC
Like # people like this
LANeo
December 9, 2020
We had a problem with this macro when there were special characters in the query result.
This filter worked well: "key IN (ABC-1, ABC-2)"
This did not: "labels IN (učebny, kanceláře)"
I can confirm that the link provided by Junio Fernandes solved our problem with the macro. (Confluence Server 7.8)
Stephanie Willis
I'm having this issue now on Cloud
Theodoros Antoniadis
November 22, 2023
I have the exact same problem even when I use the filter ID ("Filter = 99999")
November 22, 2023
I still have this problem even when I use the filter ID !
Andy Hurley
March 24, 2023
I am seeing the same issue even when there are not special characters and when I limit the displayed fields to just the key. Doesn't seem to be any workaround except to use the filteresults macro instead.
