I am connecting a test instance of Confluence with a production JIRA server.
I am trying to get the Confluence instance to use JIRA as a user server.
Below is the exception I receive from the connection test. It is obviously encrypted.
Connection works fine if I go directly through the tomcat non-ssl port 8080.
Connection fails with error below if I go through Apache port 443.
This is in the apache access log (notice the 403):
10.6.82.38 - - [09/Nov/2015:15:14:33 -0500] "POST /rest/usermanagement/1/search?entity-type=user&start-index=0&max-results=1&expand=user HTTP/1.1" 403 2084
Here are some config details worth noting:
What am I missing?
2015-11-09 14:56:44,353 ERROR [http-nio-8090-exec-5] [crowd.embedded.admin.ConfigurationController] onSubmit Configuration test failed for user directory: [ JIRA Server], type: [ CROWD ] -- referer: http://10.6.82.38:8090/plugins/servlet/embedded-crowd/configure/jira/ | url: /plugins/servlet/embedded-crowd/configure/jira/ | userName: testuser com.atlassian.crowd.exception.runtime.OperationFailedException: com.atlassian.crowd.exception.ApplicationPermissionException: ^@^@^@^@^@^@^@?U]o?6^T}??p?? ^X?^Tm???^F???:d ]?`?C ^X???"Y??????8r?^C?P^Y???y???`?^?2Tj^R^?^Q?d0?k^TdP8yg?B ?z???????????g?]?|?~z5^Y=?D-d~??d0?6 ???8 x^S?kXAkM&+p???h? ???? ???!{2XK-???????????G>??^E?Q?A??!G?5xb?L2S ????Uu!??YXgak\8??v^Yv???^B???~H???>?^??x- ?8?c^F!@V2YA???m?x?^@?v???w?D?Uf?;??c?,9?%?OQ???`??[?9????E??c??8????V^FD?P^D?}??k??-?^Bg?^U??5?1^X???>N???M ?sP ?D"?????^E ?^X? x????^X*^V??L??oz?(??Qg? n^D7^Zi_?e/?+??*?^R W^D?????Hc??"??h^??A?w??U^X??C L?^F?0??P^V??(_?C?^Q?^Q??K?a? ??!C?????n?O?_??M??D?n/???^U??)?Z??^Ru??W???F?!?S?z%^C???^D:?5?D? #???^W??^D???t?9???^d???$oF?^Zohz?";q???}^NY??6????w??`A?`t??T??^Z??G-J^E?[?x?C??m^S6?*?F}????92g?~;C?8*???s???^F"??9^V?5Q-???'C1;W?^N`g???ku?q>h?.?^D5??+?^B^U?t ?J-?g?jK? E?&c??]????;?? $????^Y????#??s%%??$?>??^??v???????3?9?C\?O+?PESC?+?c-?:?????2G?/?#2??B??&; 1??U?@^E6 ???)?$a?/! ?O?S???????_:fNESC?x~^D?d??????;??1???w^A6?}?w??1??? ??^Xw? ^Q?^?n?^VH?]I?p??cV??????? ?^Dx??^O??????~g???l?KG???^CInp?.??"?^Z???t??L???^N? ?i3??S]?^G?ed???g^A:^Y????}n??.R?^X?????^?^A??o^W;^Y^@^@ at com.atlassian.crowd.embedded.core.CrowdDirectoryServiceImpl.testConnection(CrowdDirectoryServiceImpl.java:78) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497)
I figured it out. The clue was in the Tomcat access log. I expected the proxied traffic from Apache to show up in tomcat as coming from localhost. I did not expect it to be the IPv6 localhost.
Adding "0:0:0:0:0:0:0:1" to the "IP Addresses" section of the Jira User Server configuration on my JIRA server solved the problem. (I used the long name instead of the short-hand "::1" as that is how it appears in my Tomcat access log.)
