Siteminder integartion Problem in 4.1
Mahipal Reddy November 21, 2012
We are using the site minder authentication in confluence 4.1 now we are trying to use same in confluence 4.3.
we found couple of classes changed in the confluence4.3 for authentication
so that we are getting run time errors.
We are using below method:
if (existingSession != null && existingSession.getAttribute(DefaultAuthenticator.LOGGED_IN_KEY) != null)
        	log.info("in method 3");
       Principal loggedInUser= (Principal) existingSession.getAttribute(DefaultAuthenticator.LOGGED_IN_KEY);
            //log.info("{} is already logged in."+ loggedInUser.getName());
            return  loggedInUser;
We are getting the ClassCastException
Cause
java.lang.ClassCastException: com.atlassian.confluence.user.SessionSafePrincipal cannot be cast to com.atlassian.user.User
    at com.atlassian.confluence.user.AuthenticatedUserThreadLocal.getUser(AuthenticatedUserThreadLocal.java:25)
Stack Trace:[hide]
	at com.atlassian.confluence.util.UserThreadLocalFilter.doFilter(UserThreadLocalFilter.java:36)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
	at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:30)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
	erInternal(GzipFilter.java:74)
Mahipal Reddy November 26, 2012
Thank you peter.
How we will get all Active directory and Ldap users information from "UserDirectories"
what is the bean name we need to use.
private DirectoryManager getDirectoryManager()
        if (directoryManager == null)
            directoryManager = (DirectoryManager) ContainerManager.getInstance().getContainerContext().getComponent("directoryManager");
       // System.out.println("getDirectoryManager...2"+directoryManager);
        return directoryManager;
PeterKoczan
November 21, 2012
One of our customers ran into the same problem and published his findings on this answers thread. I suggest that you review it and see if the information there is useful for you.
Peter
