×Hi all!
We are trying out some plugins for Confluence on a developer license. We had the Knowledge Base plugin working properly and then we ran an upgradefrom Confluence 5 to Confluence 5.2.
Suddenly we got this result from the pages using the macro:
<h6>Top ranked articles</h6>Error rendering macro 'kbtoparticles' : java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
We also get this result under the Configure button in the Manage Add-ons page:
Cause
org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getYesIncrement' in class com.atlassian.confluence.plugins.knowledgebase.ConfigureAction threw exception com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID) at /com/atlassian/confluence/plugins/knowledgebase/configure.vm[line 19, column 107]
at org.apache.velocity.runtime.parser.node.ASTIdentifier.execute(ASTIdentifier.java:223)caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
at com.google.common.cache.CustomConcurrentHashMap$ComputedUncheckedException.get(CustomConcurrentHashMap.java:3305)caused by: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
at net.java.ao.schema.info.SimpleEntityInfoResolver.resolve(SimpleEntityInfoResolver.java:63)Stack Trace:[hide]
org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getYesIncrement' in class com.atlassian.confluence.plugins.knowledgebase.ConfigureAction threw exception com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID) at /com/atlassian/confluence/plugins/knowledgebase/configure.vm[line 19, column 107] at org.apache.velocity.runtime.parser.node.ASTIdentifier.execute(ASTIdentifier.java:223) at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262) at org.apache.velocity.runtime.parser.node.ASTReference.render(ASTReference.java:342) at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336) at org.apache.velocity.Template.merge(Template.java:328) at org.apache.velocity.Template.merge(Template.java:235) at com.opensymphony.webwork.dispatcher.VelocityResult.doExecute(VelocityResult.java:91) at com.atlassian.xwork.results.ProfiledVelocityResult.doExecute(ProfiledVelocityResult.java:21) at com.atlassian.confluence.setup.webwork.EncodingVelocityResult.doExecute(EncodingVelocityResult.java:48) at com.opensymphony.webwork.dispatcher.WebWorkResultSupport.execute(WebWorkResultSupport.java:116) at com.opensymphony.xwork.DefaultActionInvocation.executeResult(DefaultActionInvocation.java:263) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:187) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.validation.MessageHolderInterceptor.intercept(MessageHolderInterceptor.java:42) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.util.LoggingContextInterceptor.intercept(LoggingContextInterceptor.java:49) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.core.CancellingInterceptor.intercept(CancellingInterceptor.java:23) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.xwork.HttpMethodValidationInterceptor.intercept(HttpMethodValidationInterceptor.java:72) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.security.websudo.WebSudoInterceptor.intercept(WebSudoInterceptor.java:36) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.themes.ThemeContextInterceptor.intercept(ThemeContextInterceptor.java:68) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.security.actions.PermissionCheckInterceptor.intercept(PermissionCheckInterceptor.java:57) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.setup.webwork.BootstrapAwareInterceptor.intercept(BootstrapAwareInterceptor.java:26) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.user.actions.UserAwareInterceptor.intercept(UserAwareInterceptor.java:58) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.pages.actions.CommentAwareInterceptor.intercept(CommentAwareInterceptor.java:50) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.pages.actions.PageAwareInterceptor.intercept(PageAwareInterceptor.java:151) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.spaces.actions.SpaceAwareInterceptor.intercept(SpaceAwareInterceptor.java:77) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.xwork.FlashScopeInterceptor.intercept(FlashScopeInterceptor.java:25) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.core.actions.LastModifiedInterceptor.intercept(LastModifiedInterceptor.java:31) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.core.ConfluenceAutowireInterceptor.intercept(ConfluenceAutowireInterceptor.java:49) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeAndHandleExceptions(TransactionalInvocation.java:76) at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeInTransaction(TransactionalInvocation.java:61) at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor.intercept(XWorkTransactionInterceptor.java:56) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.xwork.SetupIncompleteInterceptor.intercept(SetupIncompleteInterceptor.java:43) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.atlassian.confluence.security.interceptors.XXSSSecurityHeaderInterceptor.intercept(XXSSSecurityHeaderInterceptor.java:21) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35) at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165) at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:115) at com.atlassian.confluence.servlet.ConfluenceServletDispatcher.serviceAction(ConfluenceServletDispatcher.java:57) at com.opensymphony.webwork.dispatcher.ServletDispatcher.service(ServletDispatcher.java:199) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:50) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:70) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.security.websudo.MessagesDecoratorFilter.doFilter(MessagesDecoratorFilter.java:59) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77) at com.atlassian.confluence.util.profiling.ProfilingPageFilter.doFilter(ProfilingPageFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.plugin.remotable.plugin.module.permission.ApiScopingFilter.doFilter(ApiScopingFilter.java:63) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.jmx.JmxFilter.doFilter(JmxFilter.java:106) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.ServletContextThreadLocalFilter.doFilter(ServletContextThreadLocalFilter.java:21) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:40) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.UserNameHeaderFilter.doFilter(UserNameHeaderFilter.java:26) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.UserThreadLocalFilter.doFilter(UserThreadLocalFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211) at com.atlassian.confluence.web.filter.ConfluenceSecurityFilter.doFilter(ConfluenceSecurityFilter.java:28) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.ThreadLocalCacheFilter.doFilter(ThreadLocalCacheFilter.java:22) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98) at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:30) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:37) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:72) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170) at com.atlassian.spring.filter.FlushingSpringSessionInViewFilter.doFilterInternal(FlushingSpringSessionInViewFilter.java:29) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.ConfluenceErrorFilter.doFilter(ConfluenceErrorFilter.java:22) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.core.datetime.RequestTimeThreadLocalFilter.doFilter(RequestTimeThreadLocalFilter.java:35) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:74) at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.plugin.remotable.plugin.module.oauth.OAuth2LOFilter.doFilter(OAuth2LOFilter.java:81) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.plugin.remotable.host.common.service.http.bigpipe.BigPipeRequestIdFilter.doFilter(BigPipeRequestIdFilter.java:33) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66) at com.atlassian.confluence.extra.webdav.servlet.filter.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:427) at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:34) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:58) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.TranslationModeFilter.doFilter(TranslationModeFilter.java:43) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:53) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:25) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:50) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:602) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Unknown Source) Caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID) at com.google.common.cache.CustomConcurrentHashMap$ComputedUncheckedException.get(CustomConcurrentHashMap.java:3305) at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3441) at com.google.common.cache.CustomConcurrentHashMap$Segment.compute(CustomConcurrentHashMap.java:2322) at com.google.common.cache.CustomConcurrentHashMap$Segment.getOrCompute(CustomConcurrentHashMap.java:2291) at com.google.common.cache.CustomConcurrentHashMap.getOrCompute(CustomConcurrentHashMap.java:3802) at com.google.common.cache.ComputingCache.get(ComputingCache.java:46) at com.google.common.cache.AbstractCache.getUnchecked(AbstractCache.java:49) at net.java.ao.schema.info.CachingEntityInfoResolver.resolve(CachingEntityInfoResolver.java:32) at net.java.ao.EntityManager.resolveEntityInfo(EntityManager.java:1056) at net.java.ao.EntityManager.find(EntityManager.java:720) at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.find(EntityManagedActiveObjects.java:175) at com.atlassian.activeobjects.osgi.DelegatingActiveObjects.find(DelegatingActiveObjects.java:93) at sun.reflect.GeneratedMethodAccessor387.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307) at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58) at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56) at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204) at com.sun.proxy.$Proxy1860.find(Unknown Source) at com.atlassian.confluence.plugins.knowledgebase.DefaultSurveySettingsManager.getSetting(DefaultSurveySettingsManager.java:112) at com.atlassian.confluence.plugins.knowledgebase.DefaultSurveySettingsManager.getYesIncrement(DefaultSurveySettingsManager.java:27) at com.atlassian.confluence.plugins.knowledgebase.ConfigureAction.getYesIncrement(ConfigureAction.java:54) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.apache.velocity.runtime.parser.node.PropertyExecutor.execute(PropertyExecutor.java:142) at org.apache.velocity.util.introspection.UberspectImpl$VelGetterImpl.invoke(UberspectImpl.java:533) at org.apache.velocity.runtime.parser.node.ASTIdentifier.execute(ASTIdentifier.java:198) ... 261 more Caused by: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID) at net.java.ao.schema.info.SimpleEntityInfoResolver.resolve(SimpleEntityInfoResolver.java:63) at net.java.ao.schema.info.EntityInfoResolverWrapper.resolve(EntityInfoResolverWrapper.java:21) at net.java.ao.schema.info.CachingEntityInfoResolver.access$001(CachingEntityInfoResolver.java:11) at net.java.ao.schema.info.CachingEntityInfoResolver$1.load(CachingEntityInfoResolver.java:23) at net.java.ao.schema.info.CachingEntityInfoResolver$1.load(CachingEntityInfoResolver.java:19) at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3426) ... 301 more
I tried uninstalling the plugin and installing it again. Disabling and enabling. Nothing did the trick.
Thanks for your help!
Well, as expected this was a problem with versions of the plugins. We had to uninstall and reinstall the previous version of Confluence and restore the backup until the knowledge base plugin is updated. We are hoping it will be updated soon.
Same here... also after upgrade to 5.2.3. We were starting to use the plugin before the latest Conluence upgrade (5.1 to 5.2) but have now been stopped in our tracks! I can't downgrade our Confluence version as we also use features of it that only work correctly in the 5.2.3 version.
When can we expect to see a "fix" for this problem?
Same here...upgrade to 5.2.3, tried KB Survey plugin, no joy. Had not tried KBS plugin previously, but need it now. My exception is the same as Jorge's.
Update: I guess this plugin is not supporting 5.2. If that is the case, then the question is when will the plugin be upgraded to support it?
