Urgent help required on Indexing Repository
Deleted user February 11, 2014
System type:64-bit
I have set this in Class path
C:\fisheye\fisheye-3.2.4\fecru-3.2.4\bin;C:\software\crucible-3.2.4\fecru-3.2.4\bin;
also added two folders in C: drive- crucibledata and fisheyedata in which config.xml is present
I have added system variable:
variable name:FISHEYE_INST
variable value:C:\fisheyedata
variable name: FISHEYE_OPTS
variable value:-Xms128m -Xmx1024m -XX:MaxPermSize=256m
I can log into the admin page and I am seeing this status from past 2 days:
Scanning changesets:completed
indexing changesets:In-progress(8.4%)
Path expanded:2457 of 21998
Metadata indexed:2457 of 21998
Content indexed:2457 of 21998
Changesets done:2 of 21998
Please help me understand what is actually happening and how much time will it take for completion of Indexing. I have a deadline to be met and its urgent. So please consider and reply on Urgent basis.
AafrinA
February 18, 2014
The time taken to index varies depending on the size of the repository. Large repository might take longer time.
You can try increase the allocated memory as mentioned in the following documentation: https://confluence.atlassian.com/display/FISHKB/Fix+Out+of+Memory+errors+by+increasing+available+memory#FixOutofMemoryerrorsbyincreasingavailablememory-OutOfMemoryError:JavaHeapSpace
Increasing the memory allocation will help to avoid out of memory error
Now I am getting this error:
Your request was unable to be processed
java.lang.OutOfMemoryError - Java heap space
Java heap space
You are running release CR3.2.4 FE3.2.4 (20140115091713 2014-01-15), please report your release number when reporting bugs.
