Using Confluence to create document based knowledge base
Shawn Yates
October 4, 2011
Hi!
I have been tasked with making a lot of documents available in a searchable knowledge base. We already own Confluence so I want to leverage that. The documents live on SharePoint, but the UI there just isn't what we are looking for. The conecpt of having a page for each document with a brief summary then a link to the document is very well received.
Now, my challenge is to make the process of adding documents VERY simple for non-technical people (don't even talk about using wiki markup language). I have used Scaffold to create an "add new page" link that takes them to a easy enough page with a place to enter the doc title and a description. Easy enough.
The challenge now is how to I get them to link the document? I am hoping for some kind of "browse" button where they can browse to the doc and that will put the link right on the page.
Any thoughts? I am also open to general thoughts on how others have used Confluence to do this same thing.
Shawn
Shawn Yates
October 23, 2011
Thankks for the suggestions. I will check them both out.
I will close this question as it seems this may be as close as we get for now :).
SarahA
October 24, 2011
Hallo Shawn
This documentation may be useful:
http://confluence.atlassian.com/display/DOC/Developing+a+Knowledge+Base+on+Confluence+Wiki
It is a set of pages written by the Atlassian support team, about building a knowledge base in Confluence. One of the pages is about templates, and there are other useful techniques too.
I hope this is helpful!
Cheers, Sarah
Nic Brough -Adaptavist-
October 4, 2011
Three very quick points/ideas which may not apply to your cases
  1. My current client discourages attachments, and find the "word import" trick has enabled us to get rid of a nice wide swathe of documents completely.
  2. Confluence 4.0 doesn't have wiki markup - the editor has been rewritten. Worth a look and an upgrade?
  3. Have you looked at user macros? My thought would be a macro that you could a) stick on a template page and b) derive the document location from the title of the page? (e.g. if they called the page "My Doc 104", your macro would display a link to https://yourdocrepo/space-name/my.doc.104 and you can play tricks like "open in new window" with the url and so on)
atlassian, jira, marketing project management, jira for marketers, agile marketing, campaign planning, marketing workflows, jira templates, atlassian learning, marketing collaboration, project tracking, marketing teams, jira training
Streamline Marketing in Jira 🖼️
Plan, prioritize, and deliver marketing projects seamlessly. See how Jira supports your team's success. Start today!
Start now! 🚦
