Using the Questions Macro how do i display and ask questions that are asked within a space?
Jonathan Garrett
March 11, 2015
Currently i observe
1) The macro does not provide an ability to select the space as well as the topics, so questions that are private to a space can not be displayed?
2) The ask question button of the macro does not automatically assign questions to a space or provide the ability to determine if a question global or in a space.
Is there a way to ask and display question private to a space?
Jochen Häberle
This is a feature added to the last version of the Confluence Questions plugin. The user is asked to specify the Space a question should go to.
Additionally, every Space now has a Questions area of it's own. Questions asked there are automatically added to the correct Space.
You can administer the associated Spaces at any time.
carolyn french
I'm running across this as a problem actually. I want there to be the option NOT to associate the question to a space.
