Which code to use for breadcrumbs and best way to customize them
Matthew J. Horn
February 28, 2012
There seem to be at least 3 ways to get breadcrumbs into the "header" DIV of the Main Layout file:
  1. $!sitemeshPage.getProperty("page.breadcrumbs")
  2. #parse ("/pages/page-breadcrumbs.vm")
  3. #breadcrumbs()
#1 is the default. It's nice. Not thrilling, but nice. Example:
Dashboard > Core Doc > Home > Plug-ins > Plug-In Application Framework
#2 does not work well. Example:
Dashboard > com.atlassian.confluence.core.ConfluenceActionSupport.action.name
I've seen a couple mentions of this issue out there, but admit I haven't understood what the problem is. Maybe something about the context.
#3 works well, and I have figured out that if I modify the confluence/breadcrumbs.vm file, then I can play with the output. Example:
So, my questions, though, are:
1) What's the best way to do it? Obviously, #1 or #3 seem good.
2) Why does modifying the confluence/breadcrumbs.vm file NOT affect #1?
3) Why are there 11 different VM files with the name "breadcrumb" in them in various subdirectories of the confluence directory?
4) How to change the style? I want the breadcrumb text to be blue on a white background.
5) How to change the separator? I want to use a / instead of a >.
Thanks for any insight.
matt
felipedeboni
January 16, 2018
That's how I was able to customize it for my needs, having full html control.
main-layout (placeholder div)
#if($sitemeshPage.getProperty("page.custom-breadcrumbs"))
<div class="custom-breadcrumbs">
$!sitemeshPage.getProperty("page.custom-breadcrumbs")
</div>
#end
page-layout (breadcrumbs)
#if ($mode == "view")
#requireResource("confluence.web.resources:breadcrumbs")
#if (!$breadcrumbsId)
#set ($breadcrumbsId = "breadcrumbs")
#end
<content tag="custom-breadcrumbs">
#set ($breadcrumbs = $helper.breadcrumbs)
#set ($numCrumbs = $breadcrumbs.size())
#set ($ellipsisCrumbs = $helper.getEllipsisCrumbs($breadcrumbs))
#set ($ellipsisShown = false)
<ol id="$breadcrumbsId">
<li class="first">
<a href="$req.contextPath">Home</a>
</li>
<li >
<a href="$req.contextPath/display/$space.key">$space.name</a>
</li>
#foreach( $breadcrumb in $breadcrumbs )
#if ( $velocityCount > 2 )
<li>
<a href="$req.contextPath$breadcrumb.target">$breadcrumb.displayTitle</a>
</li>
#end
#end
</ol>
</content>
#end
And to change the breadcrumbs separator, it's just CSS...
#breadcrumbs li:before {
content: ''; /* Put whatever you want here */
Nicolas Casel
March 24, 2016
Hi @Matthew J. Horn ,
Thanks for these useful tips.
For each breadcrumb, I would like to add the current page title. I've checked the 'breadcrumbs.vm' file but I can't locate where it dynamically builds the breadcrumb path.
Any idea IT Support Atlassian ?
Matthew J. Horn
June 19, 2012
Yet another bump. Come on, Atlassian! There are almost 400 views of this thread and not one person wants to take a stab at it?!
In further interest of providing small bits of info, the #breadcrumbs() macro calls $!sitemeshPage.getProperty("page.breadcrumbs"), so that's why they do the same thing.
Matthew J. Horn
June 13, 2012
In the interest of bumping this thread, and providing some small addition bits of info, I can change the separator by editing the image files in the \confluence\images\decoration directory. Specifically, the white_breadcrumbs_indicator.png file defines the little ">" in the breadcrumb trail. Haven't bothered to look into why there are a dozen or so other files in there, too, with breadcrumb in the name...
Matthew J. Horn
February 28, 2012
I'll answer part of this myself: To change color of the breadcrumb background and the breadcrumb text, use the Admin panel > Color Scheme. Then change the value of the Top Bar and the Breadcrumbs Text colors.
