I've added One Drive for business embedded view to my page, but after publishing it's been shown as regular text link
Hello @Yevheniia Baliasna
Hope you are doing well!
By the description of the issue, if you are inserting the One Drive link in a Editor page (not Legacy Editor), it shows you on the preview/edit mode, the embedded version card of the link, but indeed upon publishing it, it shows the URL link instead.
I have reported it to our development, as you can see on the following bug report:
I have added this post as a reference for our development awareness as well, but please feel free to add any comments and watch the bug to receive updates on its progress.
Additionally, if you have the Legacy editor available, you can create a page using it and try using the One Drive macro as a workaround.
Hope this information helps in terms of clarification!
Kindest Regards,
Jessica
