Zen - Toolbar menu items become invisible if not using built-in brands
Peter Whitfield March 14, 2013
My toolbar works fine when I'm using one of the 4 built-in brands, but as soon as I copy one of them and then try to customise my brand via the brand designer suddenly all of the icons/menu items in my toolbar become invisible. If I hover over them then the dropdowns do still appear, so I know they are there - they're just invisible (except for the 'User' [my name] menu, which is still visible).
Any advice greatly appreciated.
Pete
Darryl Duke
March 14, 2013
Hi Pete, Brand names cannot have spaces in them, or the icons disappear -- this might be your problem. (We've logged a bug to fix -- Zen shouldn't allow that during the brand-copying process.) Sorry for the headache!
This turned out to be exactly what the issue was. Thankyou (both) very much for your help!
Pete
Kelli Hoyt
March 14, 2013
Hi Pete,
Sorry to hear about your frustrations! If possible, can you provide your Confluence and Zen versions, as well as perhaps a screengrab of what you're seeing?
Also, when you click on 'icons' in the brand designer, are you seeing them show up in the window?
Kelli
