chart utf-8 problem
H February 4, 2013
Hi
I am having problem with chart
It seem there is problem with utf-8 but only one Pic chart has the problem
utf-8
(on left Pie chart "names" are not printing but on the right issues are printed fine)
what do I have to make change to fix this?
H April 29, 2013
I fond a way.
I have to make fallback directory at jre
cd /usr/lib/jvm/java-7-oracle/jre/lib/fonts
mkdir fallback
cd fallback
copy the one font whitch you want to use to fallback directory
if this does not work
copy the font to jira jre
cd /atlassian/jira_hermes/jira/jre/lib/fonts
mkdir fallback
cd fallback
Bruna Griebeler
February 4, 2013
Please try to import the proper fonts inside <tt>jie/lib/fonts.</tt>
Hope it helps!
H February 19, 2013
Thank you for the comment
I imported a Korean fonts to jre/lib/fonts but it did not work.
msql is set to utf-8 .
Is there some thing I could try?
