hide Company Hub from top navigation for all users including admins
Melissa McMahon January 3, 2025
I realise this is only visible to admins, but it will still be confusing for all of them, since we have no intention of using it, and it being visible makes it look like we are or should.
Kristian Klima
Hi @Melissa McMahon
Based on this article, Hub is only available for Premium and Enterprise tiers. HOWEVER, it does, annoyingly, appear on in the bar of Confluence Standard which it seems you have.
If you can't see the Hub permissions as outlined on my screenshot, it's probably because you see Hub in the Standard's UI but, as you cannot use it, you cannot hide it...
I can confirm that on my private Confluence (Standard) I see Hub in the bar but have no permissions settings menu for it.
/facepalm - because I know my answer is not helping, just explaining what I think is going on :)
Melissa McMahon January 6, 2025
Thank you, yes, I was aware what was going on, was just hoping there was a way around it :)
Like Kristian Klima likes this
Kristian Klima
If it's the 'presentation' use case that drives your need, you can do it like we do on our public docs site
Sanam Malleswari
Hi @Melissa McMahon
By following below path. you can restrict the visibility of company hub in confluence navigation bar.
You set the restriction in the Hub permissions.
Settings>>Security>>Hub permissions
Sanam
Thank you for the answer, but I'm guessing that is only available if you've created and published a Hub? As I don't have this option in my Security settings (only Global and Space permissions). Any other options?
Sanam Malleswari
However, Company hub is available for only premium and enterprise tiers and it's  permissions. Please check your subscription plan.
I am aware it's only available for those tiers - which is why it's frustrating that it's impossible to remove the display of the feature, which is basically a (mis-leading) advertisement, as my less experienced admin users assume it's something we can have with our current tier :(
Sanam Malleswari
Unfortunately, there's no built-in way to hide features that are not available in your current plan. However, you can provide clear communication to your team about which features are accessible with your current subscription.
Connect with Atlassian support about this issue. They may consider making changes based on user feedback.
thank you
