installation problem
Cdc-surveillance
February 9, 2016
HI,
i was trying to install confluence on CentOS with Postgres. I run into a lock situation that I couldn't figure out. so I restarted both my postgres and confluence. Now I'm getting the following error below. How can I reset the installation so that i can try to configure it again:
Cause
com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.IllegalStateException: Spring Application context has not been set
    at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149)
caused by: java.lang.IllegalStateException: Spring Application context has not been set
    at com.atlassian.spring.container.SpringContainerContext.getComponent(SpringContainerContext.java:48)
Stack Trace:[hide]
	at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112)
	at com.atlassian.confluence.setup.webwork.ConfluenceXWorkTransactionInterceptor.getTransactionManager(ConfluenceXWorkTransactionInterceptor.java:28)
	at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor.intercept(XWorkTransactionInterceptor.java:56)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165)
	at com.atlassian.confluence.xwork.SetupIncompleteInterceptor.intercept(SetupIncompleteInterceptor.java:38)
	at com.atlassian.confluence.security.interceptors.SecurityHeadersInterceptor.intercept(SecurityHeadersInterceptor.java:39)
	at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35)
	at com.atlassian.confluence.setup.actions.SetupCheckInterceptor.intercept(SetupCheckInterceptor.java:27)
	at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:115)
	at com.atlassian.confluence.servlet.ConfluenceServletDispatcher.serviceAction(ConfluenceServletDispatcher.java:54)
	at com.opensymphony.webwork.dispatcher.ServletDispatcher.service(ServletDispatcher.java:199)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
	at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:46)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:64)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:58)
	at com.atlassian.confluence.security.websudo.MessagesDecoratorFilter.doFilter(MessagesDecoratorFilter.java:54)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
	at com.atlassian.confluence.util.profiling.ProfilingSiteMeshFilter.doFilter(ProfilingSiteMeshFilter.java:45)
	at com.atlassian.confluence.cache.TransactionalCacheFactoryCleanupFilter.doFilter(TransactionalCacheFactoryCleanupFilter.java:41)
	at com.atlassian.core.filters.ServletContextThreadLocalFilter.doFilter(ServletContextThreadLocalFilter.java:21)
	at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:34)
	at com.atlassian.confluence.util.UserNameHeaderFilter.doFilter(UserNameHeaderFilter.java:25)
	at com.atlassian.confluence.web.filter.MauEventFilter.doFilter(MauEventFilter.java:36)
	at com.atlassian.confluence.util.UserThreadLocalFilter.doFilter(UserThreadLocalFilter.java:39)
	at com.atlassian.confluence.web.filter.ConfluenceTimeoutFilter.doFilter(ConfluenceTimeoutFilter.java:57)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:88)
	at com.atlassian.confluence.web.filter.ConfluenceSecurityFilter.doFilter(ConfluenceSecurityFilter.java:25)
	at com.atlassian.confluence.web.filter.ThreadLocalCacheFilter.doFilter(ThreadLocalCacheFilter.java:25)
	at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter$SwapOnBootstrapFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:42)
	at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:32)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:148)
	at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:56)
	at com.atlassian.spring.filter.FlushingSpringSessionInViewFilter.doFilterInternal(FlushingSpringSessionInViewFilter.java:26)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
	at com.atlassian.confluence.util.ConfluenceErrorFilter.doFilter(ConfluenceErrorFilter.java:24)
	at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
	at com.atlassian.confluence.core.datetime.RequestTimeThreadLocalFilter.doFilter(RequestTimeThreadLocalFilter.java:37)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.confluence.tenant.TenantGateFilter.lambda$doFilter$629(TenantGateFilter.java:35)
	at com.atlassian.confluence.tenant.TenantGate$3.call(TenantGate.java:141)
	at com.atlassian.confluence.tenant.TenantGateFilter.doFilter(TenantGateFilter.java:37)
	at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:51)
	at com.atlassian.confluence.web.filter.TranslationModeFilter.doFilter(TranslationModeFilter.java:39)
	at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:72)
	at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:45)
	at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:45)
	at com.atlassian.confluence.web.filter.ResponseOutputStreamFilter.doFilter(ResponseOutputStreamFilter.java:23)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:72)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.confluence.impl.servlet.HoldingUntilStartedFilter.doFilter(HoldingUntilStartedFilter.java:88)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:64)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:217)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:518)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1091)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:673)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1500)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1456)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalStateException: Spring Application context has not been set
	at com.atlassian.spring.container.ContainerManager.getComponent(ContainerManager.java:33)
	at com.atlassian.confluence.util.LazyComponentReference$Accessor.get(LazyComponentReference.java:42)
	at com.atlassian.util.concurrent.Lazy$Strong.create(Lazy.java:85)
	at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:321)
	at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:143)
	... 179 more
Referer URL
Unknown
Guilherme V.
February 9, 2016
Hi Marcelo,
We could see that you had the Context Spring Application error, which is related to your user permissions.
We suggest following the steps from this article to resolve this problem.
After performing the steps from that article:
  1. Stop Confluence service
  2. Clear all the files inside the home folder.
  3. Start the service again.
This will trigger a new installation from scratch.
