×If possible how does it authenticates during requests ?
Sumit,
Yes, you can display issues in confluence from two separate instance of Jira.
If you have two jira application links in your confluence, when insert the jira-issue macro you should be able to choose which one you want to display the issues from.
Hope this helps
Sherry
Thanks .. this is what i was looking for.
I will investigate more on this now and will accept the answer accordingly.
Sumit
In order to authenticate successfully against JIRA, the Confluence user must also be registered as a JIRA user with the same username. check this doc for more information
https://confluence.atlassian.com/display/DOC/Setting+Up+Trusted+Communication+between+JIRA+and+Confluence
I have it configured .... app links are getting created but still there is a issue when i try to display issue from jira instance which is not primary one.
So I asked whether its possible or not to display issues in confluence from two separate instance of Jira
