no confluence system user will be create when using installer on suse 11.2
Anton July 31, 2012
I have tested it on ubuntu 11 and it works, but on suse there is no conlfuence user. I looked in the passwd and shadow.
The error message occurs when I execute the start-confluence.sh:
To run Confluence in the foreground, start the server with start-confluence.sh -fg
executing using dedicated user: confluence
su: user confluence does not exist
I'm on openSUSE 11.2 64 bit
3 votes
Alejandro Conde Carrillo
July 31, 2012
You can create the user with this command:
sudo /usr/sbin/useradd --create-home --comment "Account for running Confluence" --shell /bin/bash confluence
Please make sure this user has permissions to write in these directories:
  • <Confluence install>/work
  • <Confluence install>/temp
  • <Confluence install>/logs
  • Confluence data directory.
You can find more information in this link.
Anton August 6, 2012
Yes that works. Thanks!
Its important for all four directories to set the owner to confluence.
Dennis Kromhout van der Meer
July 31, 2012
Have you tried creating the "confluence" user?
sudo useradd --create-home -c "Confluence role account" confluence
Also, be sure that the directory you've installed Confluence to has the right permissions, for example:
sudo mkdir /usr/local/confluence
sudo chown confluence: /usr/local/confluence
For more info: Start Confluence Automatically on Linux
August 1, 2012
If you think your question is answered, please se sure to mark as answered in order to help other people find this solution :)
