After installing upm 2.4, i have in my logs theses errors:
2012-07-09 11:01:40,242 WARN [TP-Processor19] [upm.rest.async.AsynchronousTaskManager] isBaseUrlValid Configured application base URL (https://dev.orga.ch:334/wikiadm) does not match base URL from request (https://dev.orga.ch:443/wikiadm).
We use reverse proxy for authentication and redirection. But nothing change this side.
I have jumped from 1.6.4 to 2.4 with UPM.
Does someone knows where this comes from?
Thanks for help.
Michael
Hi Michael,
It seems that this issue is a bug https://ecosystem.atlassian.net/browse/UPM-2339 However please not to worry it will be fixed in UPM 2.4.1. I would suggest you to wait until the release.
Hope it helps, Josua.
Hi Josua.
Sorry for the delay.
I have upgrade to UPM 2.7 and it is working. So it was effectively a bug.
thanks.
Michael
Hi Michael,
From the log it seems that the Server Base URL doesn't match with the one the you used to access Confluence. Could you please configure it and make it the same and check whether it works? Please bear in mind on various issues that caused by mismatch of Server base URL.
Cheers, Josua.
Hi Rian,
thanks for your post.
this is a strange case:
My Server Base URL is: https:
//dev
.orga.ch
/wikiadm
I access confluence via: https:
//dev
.orga.ch
/wikiadm
I have double-check.
If I enter https:
//dev
.orga.ch:443
/wikiadm in the Base URL in Confluence, it is working.
so there must be somewhere an outgoing redirect to port 334. I will look for it, but just dont know where ???
Michael
I see, it seems that the issue on the redirection of the port. Did you configure your Confluence as per this documentation? Also please bear in mind on the UPM configuration behind firewall.
Thanks Josua for reporting this ;-)
i will then wait.
Michael
