The dynamic Help Tips box that floats near the RH side of the screen for Administrators (at least) covers active and useful parts of the screen if you don't have a very wide screen/window.
This is a real pain, particularly if you Remote Desktop to instances where you can't stretch your window at will.
See attached screenshot (on https://support.atlassian.com/browse/CSP-92799 which auto-created this post).
Hello Peter!
I believe that you got a response from a Bug Report Opened for this. But as this is closed only to you, I'll let others know the bug Report
Hope this helps others!
Guilherme
