I can't reach the switchboard using metamask. I can't access the main menu after signing I'm stuck on the login page. antbody help?
Welcome to the Community!
Could you explain what this has to do with Confluence? What is metamask? An app for Confluence?
thank you so much aNd sorry about my bad knowledge about this topic.. I wanted to connect with my metamask wallet on stake.energyweb.org and try the testnet path, but despite the connection, the switcboard did not open and I am getting an error.. I am sure I have created the VOLTA network correctly in my metamask wallet
You have not explained what this has to do with Atlassian, so I am going to guess that you are in the wrong place.
One or more of the things you are asking about is probably using Confluence as a documentation system. You have been reading their content, got stuck and tried to click on "help with metamask/switchboard/volta/the-website". But I think you hit "help with Confluence" instead, which will land you here in most cases.
I think you should go back to the docs and look for "help with metamask".
Welcome to the Atlassian Community @HA SA KE !! As mentioned by Nick please provide some more information to help you further with your queries.
