Problem: Your work is safe, but there’s an issue Refresh the page, and click Publish again.
Ninh Nguyen
April 18, 2021
I receive this when try to publish a document, it told me reload page and try to publish again. I can not revert to last publish to get off this loop.
Fail from request:
statusCode: 400, data: {authorized: false, valid: true, errors: [], successful: false},…}
authorized: false
errors: []
successful: false
valid: true
message: "com.atlassian.confluence.api.service.exceptions.BadRequestException: Error converting ADF to storage format"
statusCode: 400
Kit West
May 28, 2021
I'm seeing the same error. Can't update any pages, using different browsers on different machines, same result. I found a separate link to a related bug, but this is definitely different, not multiple pages with the same name.
Ljupcho Blazheski November 15, 2021
Similar if not the same problem occurs to me too: While published the page shows different text than when I try to edit it and shows the following error when I'm trying to update it:
Rachel West
September 21, 2021
I am also seeing this error!
