Crowd LDAP Connection Pool setting
Jiannan Tang
Hi:
My Users is below 2000.
What's the advise setting of LDAP Connection Pool .
If the Preferred Pool Size set 3, can it cause the LDAP connection timeout?
My setting
Initial Pool Size: 1
Preferred Pool Size: 50
Maximum Pool Size: 0
Pool Timeout (seconds): 3
Pool Protocol: plain
Pool Authentication: simple
Bruna Griebeler
January 14, 2013
I don't believe this can cause timeout.
Either way, you can set you pool timeout as 0 so it will be unlimited.
If for some reason you perform timeout issues synchronizing with LDAP check this doc:
https://confluence.atlassian.com/display/CONFKB/Debugging+LDAP+Connection+Properties
Hope it helps!
Jiannan Tang
If timeout setting unlimited, then the max LDAP connection could be the login users.
Does it affact the LDAP server.
