Installed Crowd Standalone not starting
Илья Боченков November 2, 2013
Hello everyone!
I have some problem with 'start_crowd.bat'. I follow documentation, but Crowd not started. I use command panel with admin rules and write 'netstat -a', but i'm not looking '127.0.0.1:8095' or anyone service who listening '8095' port.
What's may be wrong?
Peter Van de Voorde
Hi Ilya,
Did you check if your Java Home is indeed filled in?
You can do this easily by going to the command line and executing echo JAVA_HOME.
If that doesn't return the location you would expect you can follow the steps detailed here to set you JAVA_HOME variable : http://stackoverflow.com/questions/2619584/how-to-set-java-home-on-windows-7
Best regards,
Peter
Илья Боченков November 3, 2013
Thank's Peter and Jobin. I'm set JAVA_HOME in installed path Java and Tomcat with Crowd is starting.
Jobin Kuruvilla [Adaptavist]
November 2, 2013
Any error in the catalina logs? Do you have Java properly setup?
Folder logs is empty ({CROWD_INSTALL}\\apache-tomcat\logs).
Java has been installed with basic properties. Java version is 1.7.0_45.
November 3, 2013
Open a command window, navigate to the folder where start_crowd.bt resides and execute the batch file from command window. That should give some more details.
In command panel i look this:
JAVA_HOME "" contains spaces. Please change to a location without spaces if this
causes problems.
Neither the JAVA_HOME nor the JRE_HOME environment variable is defined
At least one of these environment variable is needed to run this program
But my java installed in "D:\ProgFiles\Java" and not have spaces ...
