I am doing a new installation of standalone crowd. I have an oracle10g database that i am using but i keep getting
The specified class was not found in the class path-- for Driver Class Name i have entered classes12,jar
i have put the file classes12.jar in {CROWD_INSTALL}/apache-tomcat/lib
it has the correct permissions so it is readable. I don't know where class path is being defined or where it is being used from.
I am stuck at the installation of crowd now
Janeen Kedzierski
Have you tried the following as class name?
oracle.jdbc.driver.OracleDriver
Never used Crowd with Oracle myself (using MS SQL) but according to the following page this seems to be the class name for oracle drivers (I know the link is for Crowd ID but the class name should be the same never the less): http://confluence.atlassian.com/display/CROWD/Oracle+for+CrowdID
The correct place to put the jar files are in apache-tomcat\lib as you have done. So if the above classname doesn't help, try posting the exception from the logs you are getting and we can probably help further
