How to add TLS certificate to crowd running container
saint
June 1, 2020
Running crowd application (v4.0) in kubernetes container using docker crowd image. Need TLS certificates to be installed and tomcat/server.xml to be updated in run time. Tried to map certificate and tomcat/server.xml file to shared volume, When pod spin up the shared volume data is getting overwriten. Tried to use execute command/args to image but after executing the command pod is exited (seems the command is overwritting the entrypoint command inside the pod.
Is there any solution where certificates and server.xml can be updated in runtime and then start crowd.sh
Dave Chevell
June 2, 2020
Hey @saint
tl;dr mount your custom server.xml to /opt/atlassian/etc/server.xml.j2
As per the note under the "Advanced Configuration" section of https://hub.docker.com/r/atlassian/crowd , server.xml and other config files tied to the installation folder are generated from Jinja2 templates. You noticed that server.xml is overwritten on startup; they're overwritten using the template located at /opt/atlassian/etc/server.xml.j2
Whilst our built-in template contains a number of merge fields that are resolved at startup, if you place a static file at this location it will simply be used as-is.
That should sort out your problem! Let me know how you go :)
Cheers
Dave
