Easily clean up Jira projects with project cleanup for site optimizer
Hi, I’m Mohamed Almoaz, a Senior Product Manager on the Jira team. I’m pleased to share that Site Optimizer’s functionality for Jira Cloud Enterprise plans has expanded to include project cleanup.
If you’re not already aware, Site Optimizer is a powerful, immersive dashboard that unlocks new ways for admins to efficiently manage and optimize their sites by cleaning up recommended site “clutter” like old issues, custom fields, and now— projects!
Boost performance with project cleanup
Removing old or inactive Jira projects is a great way to keep your site performant, as project bloat can degrade site speed. However, we know from your feedback that admins often struggle to manage large numbers of projects because manually cleaning up these projects is both tedious and time-consuming.
To remedy this, the new project cleanup feature lets admins streamline projects quickly and efficiently. Similar to issues and custom fields in Site Optimizer, project cleanup shows admins when project counts reach the recommended threshold, provides recommendations on old or inactive projects to clean up, and enables cleanups to be done in bulk. By bulk archiving or deleting recommended projects, you declutter your instance and improve performance.
How it works:
  • Access your recommendations: Start by clicking “optimize projects” in the Site Optimizer view. This takes you to the analysis page, which shows the total number of projects (including team-managed projects and company-managed projects) and the projects recommended for archival or deletion.
  • Filter your view: Customize your cleanup by filtering projects that are empty, without issues, or have been inactive for more than 6 months.
  • Clean up your projects: Move projects to trash or archive them to streamline your site.
Check it out below or learn more about Project Cleanup for Site Optimizer in our product documentation. Thanks for reading!
4 comments
John Dunkelberg
Thanks @Mohamed Almoaz - are there plans for cleanup of unused boards, filters, and dashboards?  Projects we generally can find when people aren't using them, but I'm not aware of any tools to help with the clutter of boards, filters, and dashboards.
Like # people like this
Mohamed Almoaz
October 14, 2024
@John Dunkelberg We are working on our roadmap and more entities will be added to Site Optimizer soon. Thanks for reaching out.
Peter Norris
This is a good start, but in order to remove old projects I need more than just the last "update" timestamp. I'd like to see the last time a record was created, also, and even, a breakdown by work item type, to get a good analysis on a project before archiving it. These are the sorts of things we look at before either archiving directly, or contacting the project lead.
Can this be considered?
Kate
Not sure if you're taking suggestions for the Site optimizer, but there's one thing that I have found makes it harder to utilise it fully.
It would be so incredibly useful to be able to export any affected data in the process of archiving/deleting assets from our Jira site. Especially given that normal Jira filters don't bring back results for archived projects.
For example, we have a number of Archived projects (because our organisation has data retention requirements for a period of time after work finishes), which makes it really hard to delete un-used Custom fields, 'cause we can't pull that data without unarchiving and checking.
