Fisheye SVN test connection problem
Rumceisz
Hi All,
we try to connect an SVN to Fisheye.
We have the correct user/password to the svn so it could not the problem.
Whenever we paste the URL of the svn and test the connection, we get this error:
Unable to get info for the repository root for Project
svn: E170001: OPTIONS of '/svn/PROJECT/project': 403 Forbidden (https://svn.xxx.xxx.xxx.de)
at
org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:62)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:731)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:362)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:350)
Unable to get Repository Root URL for OPAL:https://svn.xxx.xxx.xxx.de/svn/PROJECT/project
Exception getting FishEye access control
svn: E170001: PROPFIND of '/svn/PROJECT/project': 403 Forbidden (https://svn.xxx.xxx.xxx.de)
at
Error testing connection.
at
Connection failed.
Philippe Robichaud
Same error on our end. Have you solved it? If so, I'm interested to know more about the solution. Thanks!
Simon Shaw
August 15, 2017
We had a similar issue after creating a new SVN server.
Turns out Fisheye is caching credentials somewhere.
Log files on the SVN server were showing User X was trying to connect (the old username) despite User Y being in the dialog in Fisheye.  Going back to the old User X account worked but seems to be a bug?
Thomas Bennett December 22, 2013
Anyone solve this? I have the same issue with a 405.
鹏 许 October 23, 2013
me too! I found the problem is that somebody change files of fisheye owner on linux. I return it to sovle this problem.
