Crucible Jira Issues are going unassiged?
Avdhesh Chauhan
May 30, 2012
I am creating Jira issues through crucible but it is going unassiged please help me regarding this..
Alok kumar Singh
Did you add users to the project for which you are creating the issue in JIRA. After adding the users you can assign the issue explicitely....
Alok kumar Singh
If you like the answers....mark it as accept...
Avdhesh Chauhan
May 31, 2012
But as stated earlier our problem is still same.
we are creating issues from crucible and still issues are going unassigned in our JIRA.
"The issue is created, but in JIRA its unassigned - though in JIRA we have made settings "Allow unassigned issues as NO", the same we did while integrating the JIRA with fisheye aas well"
Please help us regarding the same.
Alok kumar Singh
Once after creating your review, go to Edit Details>>Reviewers(when you click on this it will show the added users) you would be able to add only users who has been added to the particular project for which you are creating the review>>Done.
Avdhesh Chauhan
May 31, 2012
Thanks for the update, we are able to get the users name in the dropdownlist when we create review
We are assigining to a particular users, who has access to the project in JIRA (both JIRA and Fisheye use LDAP credentails only)
Avdhesh Chauhan
May 31, 2012
Somebody please help on this, this is very critical for us??????
Jobin Kuruvilla [Adaptavist]
May 30, 2012
Set up issues to be assigned to Project lead by default or to Component lead by default. Or do you want to assign to specific people on issue creation?
Avdhesh Chauhan
May 31, 2012
Sir we want to assign to a particular user?
as in crucible we are getting option to choose the user, still we are choosing the user name in crucible but still it going unassigned.
please help sir.
May 31, 2012
Does that user has assignable permission in the project you are creating the issue?
Renjith Pillai
May 31, 2012
Didnt understand your statement "as in crucible we are getting option to choose the user". AFAIK Crucible does not have a feature to select who will be the assignee for the issues created. The user you specify is used to create the issue.
Why don't you assign a workflow condition for the sub-task type that you have mapped in Crucible to assign the issue to a particular user.
And if you can tell me what is the reason for such a usecase to assign all the issues to a single person?
