I find this somewhat frustrating and haven't figured out what causes or how to fix it. We use mercurial and sometimes when I add files to a review I'm creating the file list will end up with two versions of one of the files where the change sets are spread between the two files instead of having a single file with all of the change sets.
For example, I currently have a review I've created and a file is duplicated in the review where one version has change sets 628, 648, 650, and 651. The other version of the file has change sets 644 and 649.
I will say that this is a branch and I had merged changes from our main branch into this branch which may have something to do with this.
So what is causing this and what should I do to fix it?
Let me also add that one file show as "File Outdated" on the right top menu (where View and FishEye are).
This can sometimes happen when adding a changeset which includes a merge, or when the changeset has revisions which are not on the same ancestry line as the files which are already in the review. This is unfortunate, and a case which Crucible doesn't handle very well at the moment. Let me explain:
Consider "file.txt" which has the following revision graph:
3 ----- 4 ----- 5 / / / / / / 0 ----- 1 ----- 2
If you review contains changeset "2" (ie, the diff from 2:1), and then you add the change made in the merge commit (rev 4) then Crucible can show doubled files. This is because Crucible will choose the first parent (4:3) to add to the review (this is a bug), and revision 3 is not on the same ancestry line as revision 2 (the latest revision of file.txt in the review). In order to show all the revisions, we currently show the file duplicated as a way to ensure that the reviewer can see all the relevant diffs. The logic to view the files in Crucible isn't wrong - but rather adding the revision is incorrectly done.
I believe a workaround is to manually edit the review and remove the revision "3" from the review and refresh the page. I think that will cause Crucible to correctly render the lineage diff of 4:2:1 rather than 4:3 and 2:1. (nb: I haven't tried this recently)
We are currently tracking this bug at https://jira.atlassian.com/browse/CRUC-5229 where you can vote for it or add your feedback.
Seb
Seb, Not sure you saw my message below (I should had added it as a comment to your message but instead it got added as an "answer" which it isn't). I would appreciate it if you could consider the comment and give me a response. We have developers that are quite frustrated with the crucible tool to the point of suggesting that we start looking at alternatives but I would prefer to stick with this tool because of the integration with Jira, which we use.
This issue seems to be related https://jira.atlassian.com/browse/CRUC-6568.
First, thank you for the response.
What happens then with the following:
3 ----- 4 ----- 5 ----- 6 / / / / / /0 ----- 1 ----- -------- 2 |
is it still the case where I need to remove 3?
And does this further have a problem if we have a branch where there were periodic merges from a main/release branch into the development branch... does it end up needing to remove each of the merge points from the review?
4 ----- 5 ----- 6 ----- 7 ----- 8 ----- 9 / / / / / / / / /0 ----- 1 ----- -------- 2 ----- ------- 3 |
So no one has any comment on this? Do I need to go the official ticket route?
